Added a build video in the project details!
Cleaned up the code a little bit:
--- took out some of the bits that were hanging out from other instruments).
--- Have also modularized the step-taking to be a function call to keep the forever loop looking a little cleaner.
Soon:
Plan on making the instructions a bit more detailed, and clearly defining the Bill of Materials. Also need to add in the step file/build files the little laser cut "clip" piece that helps hold the two halves of the base plate together.
TheMixedSignal
