IRON Man ARC Reactor
Hii Friends Today I'll Show You How To Make Simple DIY Eclipse Wall Light Using ESP8266
SO LET'S Make It
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I created this project after I was inspired by smartphone controlled neopixels in a friends house but his were shop-bought. I thought "how hard can it be to make my own, it would be much cheaper too!"
(✯ᴗ✯) (✯ᴗ✯)
Supplies:
Hardware:
Ws2812b RGB Led Strip
Wires
: Buying these from local shops would be a better
Software:
Arduino IDE
BLYNK App
Print Your Plate With 3D Printer
I made this plate using 3D printer
If you don't have a 3D printer, don't worry, you can make it without a 3D printer.
You will need a box lid
And you can use it to make it ):
I have used ESP8266 in it, if you also have Wemos D1, then we can use it
Thanks Nextpcb for Sponsoship
If you don't make your PCBs yourself, where do you make them?Personally, I do not have the space and the courage (nor the skill) to do them myself.For SF, I turn to Util-Pocket, because I find that the quality is excellent for t
