To illustrate to density of this design, here's an XY table next to a compactly arranged stack of what's in it.
(for completeness: the assembled example has none of the running gear actually "in" it, which would make it ~1.5mm taller)
A project log for Minamil 2dc: a minimal CNC mill
Each axis: ̶$̶5̶ ̶$̶8̶ $10 motor+lead screw, 3x LM6UU, 3x 6mm x 100mm rod, 1/8in hardboard, PC case screws
Can you please post a sequence of photos showing how this thing goes together? It looks interesting, but I can't quite imagine where everything is under there, or how the leadscrews are mounted.
I'm sorry it's not already here! (see next log)
I hope to get back to this soon.
