Ever since I finished the #atmega_screen the RGB LED has bugged me as its far too bright even after I sanded the clear plastic to make it slightly opaque. While I was looking for some nuts and bolts in my random nut and bolt box I found these nut covers.
I cut the dome part off and glued it over the RGB LED on the #atmega_screen. I think it turn out pretty well considering
Here is a shot at it lit up. Its really hard to get a good picture when its lit up
I added in software the ability to toggle the RGB LED and the screen for when you don't want to glaring at you while watching a film or what not
