To keep everything organized I moved everything vacuum related to a new project and kept everything from the arc welder circuit at this project.
If you are interested in how it goes on with the vacuum project, you can find it here:
Fighting Oxidation with Vacuum | Hackaday.io
If you are interested in the arc welder circuit + optically controlled plotter circuit you can have a look at this project.
