I built a quick prototype, and it seems to be functional. I didn't have the right transformer, so I could not get the negative supply voltage. This meant that the output voltage could only be a minimum of 1.25v. I also didn't have a big enough load resistor to test it fully. Parts are in the mail for the final build.
