Put daylight-loading film developing tanks into use again
Rondinax Sealing.stlSTL file containing Rondinax 35U replacement rubber sealing 3D modelStandard Tesselated Geometry - 248.00 kB - 08/29/2020 at 13:17 |
I created and tested with my tank a replacement rubber seal. I printed it with soft TPE filament and the result is great – smooth turning without leaks. The model itself is rather simple: height 5.0 mm, outer diameter 20.0 mm, and inner diameter 11.3 mm.
Recommendations for printing are as follows:
