I drilled a hole through the shaft and put a stainless screw through the shaft and pulley, hopefully this will stop it from slipping. I cannot test for a few days because of high winds. I would normally only sail in these conditions, after all, the boat can sail much faster than it will ever go on solar power.
sean d'epagnier
