Procedure for using I2C sensors¶
- Scan for Sensors
- Click to monitor via analog gauge
- List of I2C sensors supported thus far (Minimal data logging. Configuration options via the graphical utility might be incomplete)
- MPU6050 3 Axis Accelerometer, 3 axis Angular velocity (Gyro)
- MPU9250 9-DOF sensor
- MS5611 : 24 bit pressure and temperature sensor. Can resolve 15cm height variations
- TSL2561 Luminosity measurements
- BMP280 Pressure and Temperature sensor
- MCP4725 Single channel DAC
- PCA9685 PWM controller
- MLX90614 Passive IR
results from a Malus Law experiment carried out using a TSL2561 Luminosity sensor, a laser diode, two pieces of polarizers ripped out of an LCD screen, and a hollow shaft stepper motor
Jithin
