KuttyPy hardware can be connected to an android phone via a USB OTG cable.
The app has basic IO capabilities implemented, and can also log data from 2 sensors as of now
- MPU6050 - a 6 DOF intertial measurement unit
- BMP280 - Pressure and temperature sensor
Around 8 more common I2C sensors will soon be ported
The source code link is on the homepage, and is begging for contributors. I am very new to android coding, and it is rather painful.
The app currently supports only ATMEGA32 (version code 99), but can easily be extrapolated to include 238p(Arduino Uno/Nano). No modifications will be required for the I2C sensor loggers since the registers are the same on both processors.
Jithin
