Enclosure was designed to allow easy swapping of different LED modules. Design itself is easily 3D printed on home FDM printers. Main parts are:
- Power switch, charging input and external trigger connector located at the back of the enclosure.
- Embossed markings for power, mode, temperature safety and charging indication.
- Big and ergonomic tactile switch for turning on the LEDs.
- Magnetic UV filter to protect operator from reflected UV radiation.
- Push-in mount for mounting the device. Push-in GoPro mount adapter available.
- Easy to disassemble enclosure with two fasteners for easy access.
3D model of complete assembly is available in the project repository. There are also ready to print .stl files. Here are some renders of the new prototype enclosure.
