Pictured below is a removable LED module. It is designed to be easily 3D printed on any hobbyist 3D printer. To increase airflow, a mesh pattern was incorporated into the design.
*Fully assembled LED module inside and outside of 3D printed enclosure.
REMOVABLE LED MODULE IS MADE OUT OF:
- PCB with array of LEDs, either PCB with array of LEDs, either with PQ2N-3FLE-AFC or LTPL-C034UVD365.
- PCB with connector to interface with main controller module.
- Aluminium extrusion heatsink.
- Thermal transfer compound between PCB and heatsink.
- Thermistor to monitor LED temperature.
- Lens with lens holder.
- Fixing screw.
*Pictured are two different LED modules during assembly process. One is without enclosure.
Mile
