JLC. A six-layer PCB is pretty expensive with its one-off setup costs, but hopefully it will be worth it. I have assembled two separate BOMs - one "default" with through-hole components, and a second with SMT parts. All links but one are from Digikey; the FPGA itself is unfortunately not available there, but Mouser have it, so there you go...
