About a month ago, I moved into a new [to me] craftsman style home built in 1915. It's one of those homes where every part of it feels like there's history and stories to tell. Like the utterly overgrown greenhouse in the backyard that has been sitting dormant for ~50 years. Or the "doorway to nowhere" that opens to a 4-foot drop from the living room to outside. But I digress...
The front door is large (48" wide) and made of beautiful solid heavy wood with an antique mortise lock. As far as I can tell, the door and lock are entirely original. Over the years, the house has settled, and the door sticks terribly to the frame when opening and closing. Once you get the door open (or closed), the latch of the mortise lock sticks in the open position. At least the deadbolt works.
I figured it would be an easy job: Take the door off the hinges, square it up to the frame, and clean the lock. Join me on this adventure in which I learn way more about old locks than I ever expected.
Jeremy
Thank you Jeremy! I had the same lock on my front door and it was also that spring which was missing for me. I ordered the spring you suggested and after some trial and error i got the door working again!
