The Electronic circuit chip LGE3556C is a lead frame electronic circuit component used in the electronic circuit devices with reduced storage and smaller equipment electronic module. Besides the light wright and compatible design, it is also suited for the miniature applications and variable electronic temperature sensing elements.
Utsource LGE3556C Electronic Component
It is durable and reliable for the extensive engineering applications and domestic purpose suitable products for the fast switching capability and transverse facility. The special advantage of using these LGE3556C electronic components is the usage and fit design fabrication of LGE3556C on the electronic board. So it is well situated and transverse condition power electronic switching circuit automation electronic component with switch, telecommunication, backlights and many other wide range of engineering applications.
Key Features of LGE3556C:
- Highly compatible with automation platforms on board
- Reliable and durable
- Smaller size easy to fit
- Shows good simulation and modulation property
- Compatible with reflow piece module circuit system
Overview and layout of LGE3556C:
The basic layout and overview of LGE3556C is shown in the figure below describing all the thermal specifications, electrical characterises and functional operation.
LGE3556C Overview layout of LGE3556C
So this is the basic overview of LGE3556C showing the heat sink terminology and automation technology for data transmission power electronic switching circuit.
Applications of LGE3556C:
As shown in the figure below it is used in the wide range of automotive and telecommunication electronic devices. In addition to the severe sensitive electronic modules it is also used in switching power electronic module systems and indicator backlight for the general use.
LGE3556C telecommunication application
- Automotive applications
- Dashboard switch and temperature sensing materials
- Telecommunication applications
- Flash backlight indicator
- For general domestic purpose electronic device also
LGE3556C Alternatives/Replacement/Substitute/Complementary:
If you are unable to get the LGE3556C then you can also use the replacement, substitute or an alternative of LGE3556C which shows similar functional and thermal specifications of LGE3556C.
So the replacement of LGE3556C is LGE3556CBGA, LGE3556CP
You can use these chips as a replacement of LGE3556C because of the similar electrical and thermal properties.
Equivalent part number of LGE3556C:
The equivalent part number of LGE3556C is LGE3556CP
Conclusion:
The electronic chip LGE3556C is highly compatible, reliable and efficient for the wide range of application in both commercial and domestic purposes. The device selection and carrier type dimensions of LGE3556C is best for the telecommunication heat sink absorbance capability and reverse voltage transformation of the electronic device.
