Hackaday.io Hackaday.io
Sign up Log in
Revived Vacuum Fluorescent Display Clock
dimaDima
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 2
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
698
0
5
8
Team (1)
  • dimaDima
Join this project's team
  • Nixie Dream
completed project
hardware
nixie clock tube clock nixie tube clock
Related lists
Timepieces
Straightforward or Fully Obfuscated; How do you like to tell time?
Clocks, clocks, and more clocks
If it has a timekeeper, it belongs in this list!
This project is submitted for
  • Reinvented Retro Contest
This project was created on 09/03/2020 and last updated 5 years ago.
Description
With a passion to old vacuum fluorescent display tubes display technologies I have built a VFD tube clock which I would like to present for your review. If you like colorful neon tubes as they appear in the streets of big cities in the dark of the night, you will be thrilled to have such a tube clock. It will trigger in you memories associated with those retro times when neon lighting was the technological innovation. A distinctive design, precise time keeping and a modern electronics inside - all this is offered by this model.
This Tube Clock is supplied completely assembled and tested with six IV-11 VFD tubes.
It runs by electricity from in-house 110/220V power socket as usual, but also has an integrated Lithium battery, so that there are no problems in case of power outages.
The VFD tubes show the time and date, they have a beautiful floor lighting and when changing the hours/minutes/seconds there are eyes-cathcing and very attractive effects.
Components
  • 6 × VFD Tubes IV-11
  • 1 × Wooden enclosure
Project Logs
Collapse
  • Opening an online store
    Dima • 05/11/2021 at 10:37 • 0 comments
    I have recently launch an online store where you can see all my nixie clocks and VFD clocks. They all available for sale.
    You can visit it here: http://nixiedream.com
View project log
Log In/Sign up to comment
Sign up with Github
OR
This is a simple LED clock that always displays the exact time, thanks to it being connected to a 802.15.4 network.
Project Owner Contributor
Chip Shortage Long-Range Clock
discreet-mayorDiscreet Mayor
A binary clock that displays hours, minutes, seconds in groups on a square grid.
AT90S1200 Binary Clock
danielDaniel
old flip-dot matrix display repurposed as a clock
Flip-dot clock
pauliusbaupauliusbau
Supplyframe DesignLab: 2023 Hackada…
This clock uses solenoid operated pinball score reels and flip dots for the time display.
Pinball Score Reel Clock. Abra-Ca-Dabra
timebanditclocktimebanditclock
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Revived Vacuum Fluorescent Display Clock", please tell us the reason.
Send message
Remove Member
