Assembler
- vasm - Assembler
- Built from source on Linux.
C Compiler
- GCC - 68k Cross-compiler
Build environment
- Run in VirtualBox under Windows.
Example Software
Makefile for Rectangles code
ARCH = 68000
BASE = /opt/m68k-elf/bin/m68k-elf
CC = $(BASE)-gcc
LD = $(BASE)-gcc
AS = $(BASE)-as
CP = $(BASE)-objcopy
DUMP = $(BASE)-objdump
VASM = ../../../vasm/vasmm68k_mot
# we use crt0.s from here
STARTUP_DIR = ../../Firmware_Common
COMMON_DIR = ../../Firmware_Common
BUILD_DIR=m68k_obj
STARTUP_SRC = $(STARTUP_DIR)/startup_app.s $(STARTUP_DIR)/premain.s
STARTUP_OBJ = $(patsubst $(STARTUP_DIR)/%.s,$(BUILD_DIR)/%.o,$(STARTUP_SRC))
COMMON_SRC = vga.c uart.c interrupts.c
COMMON_OBJ = $(patsubst %.c,$(BUILD_DIR)/%.o,$(COMMON_SRC))
MAIN_PRJ = Rectangles
MAIN_C_SRC = rectangles.c
MAIN_C_OBJ = $(patsubst %.c,$(BUILD_DIR)/%.o,$(MAIN_C_SRC))
MAIN_S_SRC = draw.s
MAIN_S_OBJ = $(patsubst %.s,$(BUILD_DIR)/%.o,$(MAIN_S_SRC))
MAIN_OBJ = $(COMMON_OBJ) $(MAIN_C_OBJ) $(MAIN_S_OBJ)
LINKMAP = $(STARTUP_DIR)/ldscript_app.ld
# Commandline options for each tool.
CFLAGS = -m$(ARCH) -I. -c -O6 -DDISABLE_UART_RX -I$(COMMON_DIR)
LFLAGS = -m$(ARCH) -nostartfiles -Wl,--relax -O6
# Our target.
all: $(BUILD_DIR) $(MAIN_PRJ).sre $(MAIN_PRJ).rpt
clean:
rm -f $(BUILD_DIR)/*.o *.elf *.sre *.rpt *.map *.lst *.srec *~ */*.o *.bin
# Convert ELF binary to bin file.
%.sre: %.elf
$(CP) -O srec $< $@
%.rpt: %.elf
echo >$@ -n "End of code:\t"
$(DUMP) -x $< | grep >>$@ _romend
echo >>$@ -n "Start of BSS:\t"
$(DUMP) -x $< | grep >>$@ __bss_start__
echo >>$@ -n "End of BSS:\t"
$(DUMP) -x $< | grep >>$@ __bss_end__
cat $@
# Link - this produces an ELF binary.
$(MAIN_PRJ).elf: $(STARTUP_OBJ) $(MAIN_OBJ)
$(LD) $(LFLAGS) -T $(LINKMAP) -o $@ $+ $(LIBS)
$(BUILD_DIR)/%.o: %.c Makefile
$(CC) $(CFLAGS) -o $@ -c $<
$(BUILD_DIR)/%.o: $(COMMON_DIR)/%.c Makefile
$(BUILD_DIR)/%.o: %.s
$(VASM) -Felf -o $@ $<
$(BUILD_DIR)/%.o: $(STARTUP_DIR)/%.s
$(BUILD_DIR):
mkdir $(BUILD_DIR)
