Here's the serial output:
Conducting sanity check...
Firmware received - launching
Heap_low: cef0, heap_size: 1ff2110
Mouse timed out
Initialising SD card
SPIspin
Done - waiting
Done
SPIspin
Done - waiting
Done
cmd_CMD8 response: 1
CMD8_1 response: 0
CMD8_2 response: 0
CMD8_3 response: 1
CMD8_4 response: aa
SPIspin
Done - waiting
Done
CMD55 1
CMD41 1
SPIspin
Done - waiting
Done
CMD55 1
CMD41 0
CMD58 0
CMD58_2 c0
SDHC card detectedSwapping byte order of partition entries
Start: 8192
PartitionCount: 1
Partition: 0 Start: 8192 Size: 62325760
Read boot sector from first partition
FindDrive() returnedC024576)
Changed directory
Dhrystone Benchmark, Version 2.1 (Language: C)
Program compiled without 'register' attribute
Execution starts, 25000 runs through Dhrystone
Execution ends
Final values of the variables used in the benchmark:
Int_Glob: 5
should be: 5
Bool_Glob: 1
should be: 1
Ch_1_Glob: A
should be: A
Ch_2_Glob: B
should be: B
Arr_1_Glob[8]: 7
should be: 7
Arr_2_Glob[8][7]: 25010
should be: Number_Of_Runs + 10Ptr_Glob-> Ptr_Comp: 35210
should be: (implementation-dependent) Discr: 0
should be: 0
Enum_Comp: 2
should be: 2
Int_Comp: 17
should be: 17
Str_Comp: DHRYSTONE PROGRAM, SOME STRING
should be: DHRYSTONE PROGRAM, SOME STRINGNext_Ptr_Glob-> Ptr_Comp: 35210
should be: (implementation-dependent), same as above Discr: 0
should be: 0
Enum_Comp: 1
should be: 1
Int_Comp: 18
should be: 18
should be: DHRYSTONE PROGRAM, SOME STRINGInt_1_Loc: 5
should be: 5
Int_2_Loc: 13
should be: 13
Int_3_Loc: 7
should be: 7
Enum_Loc: 1
should be: 1
Str_1_Loc: DHRYSTONE PROGRAM, 1'ST STRING
should be: DHRYSTONE PROGRAM, 1'ST STRINGStr_2_Loc: DHRYSTONE PROGRAM, 2'ND STRING
should be: DHRYSTONE PROGRAM, 2'ND STRING
User time: 2920
Microseconds for one run through Dhrystone: 116
Dhrystones per Second: 8561
VAX MIPS rating * 1000 = 487132 MB of allocated memory (33,497,360 bytes)
land-boards.com
