Also, got the code running on the the QMTECH EP4CE15 FPGA "Starter Kit". Details here.
Specifications
- On-Board FPGA: EP4CE15F23C8N;
- On-Board FPGA external crystal frequency: 50MHz;
- EP4CE15F has rich RAM resource;
- EP4CE15F has 15K logic cells;
- On-Board Winbond SPI Flash W25Q64, 8M bytes for user configuration code;
- On-Board 32MB Winbond SDRAM, W9825G6KH-6;
- On-Board 3.3V power supply for FPGA by using MP2315 wide input range DC/DC;
- Cyclone IV Starter Kit provides camera interface, 2xPMOD headers and 40P Male header for User IOs;
- Cyclone IV Starter Kit has 2 user switches;
- Cyclone IV Starter Kit has 2 user LEDs;
- Cyclone IV Starter Kit has JTAG interface, by using 10p, 2.54mm pitch header;
- Cyclone IV Starter Kit provides GMII Ethernet by using RealTek RTL8211EG;
- Cyclone IV Starter Kit provides 7-SEG LEDs;
- Cyclone IV Starter Kit provides USB to UART serial port by using CP2102-GMR;
- Cyclone IV Starter Kit provides VGA 5-6-5 interface by using resistor dividers;
- Cyclone IV Starter Kit PCB size is: 9.96cm x 9.96cm;
- Default power source for board is: 1A@5V DC, the DC header type: DC-050, 5.5mmx2.1mm;
land-boards.com
