Squeal & Scrape
github
DIY electronic musical instrument The instrument is a combination of piezo disc as contact microphone to 9v battery-powered LM386 amplifier PCB to loudspeaker. Overdriven textures and feedback are easy to produce, difficult to control, fun to play with.
Squeal & Scrape actives listening to instrument as it works in an environment.
workshop
Squeal & Scrape is a DIY electronic musical instrument. It is a version of a circuit called the smokey amp which is a version of the schematic on the LM386 IC datasheet.
The build consists of a portable, battery-powered amplifier and a contact microphone, which can be used to create howling feedback (Squeal) and/or reveal the sounds of everyday objects through touch and movement (Scrape).
The project is suitable for DIY enthusiasts, audio technicians, music producers and anyone interested in experimenting with electronic sound.
barryjosephcullen
The-Devil-Itself
Adam Redfern
youkito1991
Steph
