Between July and November 2015, a number of improvements were made to the endoskeleton!
First off, that weird "double knee" thing going on was removed, and a single-axis design was implemented using a servo motor on each side.
Next, we made the foot smaller, and switched to aluminum from steel. A hinged front toe was also added.
Next up, arms would be added to the torso.
Anthrobotics
