Hackaday.io Hackaday.io
Sign up Log in
DIY Arduino Parallax 3D Display
Two 1.3" low cost 240x240 LCDs are used to create a 3D Display that needs no glasses.
madaeonMadaeon
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
2.8k views
2 comments
2k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
Public Chat
2.8k
2
2k
5
Team (1)
  • madaeonMadaeon
Join this project's team
ongoing project
This project was created on 09/11/2020 and last updated 2 years ago.
Description
Testing Arduino controlled DIY low cost Parallax 3D Display: two 1.3" low cost 240x240 LCDs are used to create a 3D Display that needs no glasses, and can be easily intefaced with Arduino and similar microcontrollers.The 3D effect is much more intense when seen directly, it is quite difficult to record. I wrote a program in Delphi that reads a stereo photo pair and creates a single bitmap with alternated Left and Right "strips" of customizable width. One screen has backlight and shows the photo. The other has the backlight removed, and is used to show the black /white strips for the parallax effect.Theory of parallax system for 3D displays: https://en.wikipedia.org/wiki/Parallax_barrier . Inspiration from http://spritesmods.com/?art=3dmonitor&page=1.
Project Logs
Collapse
  • Testing the first working prototype
    Madaeon • 09/11/2020 at 12:59 • 0 comments
    This is the first working prototype. More info will be added soon. The effect is much better in person. There are some parts of the video where the recorded effect can still be seen, like the glove of the female boxe fighter that "moves" as the camera shifts.
    A lot of useful info here: http://displayblocks.org/diycompressivedisplays/layered3d/ (including how to align the screens).
    Many stereo photo pairs here: https://urixblog.com/en/category/species-en/humans-en/
View project log
Log In/Sign up to comment
Sign up with Github
OR
Madaeon wrote 09/15/2020 at 07:50 • point
Hi! The effect that is normally achieved by the lenticular lens, here is replicated by the parallax barrier (that is, the front Lcd without backlight, showing a pattern of alternated white/black lines).
Mike Szczys wrote 09/14/2020 at 21:08 • point
Proof of concept looks pretty good in the video. Are you using some type of a filter or lenticular lens to make sure light from each screen is directed (or blocked) so that each eye only sees light from one screen?
A 3D printed, sliding, cam-locking clamp for vertically mounted din rail. Originally designed for an orchid / staghorn fern display system
Project Owner Contributor
Vertical Din Rain Slide Clamp
brandon-heyerBrandon Heyer
Flip-Dot display with 3D-printed housing controlled by an Arduino.
Flip Dot Display
davidDavid
eDOT - Arduino based precision clock and weather station, multipurpose information display
eDOT - Arduino based precision clock and WS
antielectronantiElectron
A Sci-Fi 3D Printed Winter Soldier Mask With Transparent Displays.
Sci-Fi 3D Printed Mask With Transparent Display
mukesh-sankhlaMukesh Sankhla
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY Arduino Parallax 3D Display", please tell us the reason.
Send message
Remove Member
