Make complex tasks like Image Recognition and Object detection simple with the AI-powered HuskyLens module and transmit that data on LoRa.
Hey, what's up, Guys! Akarsh here from CETech.
In this project, we are going to have a look over the HuskyLens from DFRobot. It is an AI-powered camera module that is capable of doing several Artificial Intelligence operations such as Face Recognition, Object Recognition, and Line Recognition, etc.
It is somewhat similar to the MatchX module which we discussed some time back in this project. As the MatchX module was a bit expensive, I decided to make something similar on my own and for that, I found HuskyLens as a great choice because it is cheaper in comparison to the MatchX module and can do everything that the MatchX can except one i.e transmission of data and for that purpose we will interface the Huskylens module with RYLR907 LoRa module from Reyax and we will be good to go. After the interfacing, we will use this HuskyLens to detect an object and send that detected data using the LoRa module to another LoRa module at the receiver side.
So let's get to the fun part now.
Do check out PCBGOGO if you need to get PCBs manufactured or assembled. They welcome your PCB prototype order: PCB fabrication order quantity from 5PCS and PCB assembly order quantity from 1PC.
Since established 5 years ago, PCBGOGO has reformed several times. It is a growing PCB fabrication and assembly manufacturer in a changing world. At present, their daily PCBs and PCB assembly order quantity exceeds 3000, and the sales have increased from $100,000 to $20 million a year. Though PCBGOGO is only 5 years old, their factories, with over 400 workers now have been providing PCB manufacturing and assembly for domestic customers in China for more than 10 years.
You are lucky to read this project article, as, at this time, PCBGOGO welcomes its 5th anniversary and give out great benefits to their customers.
Join PCBGOGO to get the benefits now from here. Up to $150 Coupons, Stylish Souvenirs
HuskyLens is an easy-to-use AI machine vision sensor with 6 built-in functions: face recognition, object tracking, object recognition, line-following, color detection, and tag detection. It is a pretty neat module that comes with a camera on the front side and an LCD display on the backside and 3 LEDs(2 white and 1 RGB) onboard which can be controlled through the software. It has two buttons on it, One a slider switch to toggle between the modes of operations and a pushbutton to capture and learn about the objects in front of the camera.
The more it learns, the smarter it is. The adoption of the new generation AI chip allows HuskyLens to detect faces at 30 frames per second. Through the UART / I2C port, HuskyLens can connect to Arduino, Raspberry Pi, or micro:bit to help you make very creative projects without playing with complex algorithms.
Its Technical specifications are:
Product Link: https://www.dfrobot.com/product-1922.html
