Hackaday.io Hackaday.io
Sign up Log in
Unnecessarily complicated hand sanitizer dispenser
Touchless alcohol dispenser
miroslav-hancarMiroslav Hancar
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
100
0
1
2
Team (1)
  • miroslav-hancarMiroslav Hancar
Join this project's team
hardware
ongoing project
This project was created on 09/14/2020 and last updated 6 years ago.
Description
The goal of this project was to make use of some old components and to improve my poor Autodesk Inventor skills. I designed a simple 3D printable tank filled with a mixture of alcohol and water.
Dispenser is powered by one Li-Ion cell or from charger.
Proximity of hand is detected by a cheap ultrasonic sensor HC-SR04. PIC16F1786 measures the length of echo pulse from HC-SR04 and activates the pump if the hand is aprox. 4 cm from the sensor. The display shows the number of uses and the voltage of battery.
Details
Log In/Sign up to comment
Sign up with Github
OR
Turn Elster V200 meter into a smart water meter
Project Owner Contributor
Hacking Water Meter
alexander-dvorkovyyAlexander Dvorkovyy
Extremely useful and adjustable sensor which have several advantages including high reliability, long lifespan
DIY simple Capacitive Proximity sensor
mircemkmircemk
Scientifically prove your intoxication in style with this internet connected breathalyzer!
IoT Breathalyzer
dominicDominic
The 2017 Hackaday Prize
Temperature&Humidty sensor WiFi on battery less than 10$
ESPIOT
faire-soi-memeFaire-soi-meme
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Unnecessarily complicated hand sanitizer dispenser", please tell us the reason.
Send message
Remove Member
