Hackaday.io Hackaday.io
Sign up Log in
Hackpad
Modify your old tablet and make it useful for your prototypes and creation of Arduino projects in addition to being used for etic haking
angelo-disingangelo-dising
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
611
0
2
2
Team (1)
  • angelo-disingangelo-dising
Join this project's team
ongoing project
Haking hardware Old android tablet Old android Haking android
This project was created on 09/15/2020 and last updated 6 years ago.
Description
Reuse old tablets to use in conjunction with an Arduino hacking processor and memory get better results than factory ones and avoid throwing old electronics
Project Logs
Collapse
  • Scrached screen
    angelo-dising • 09/15/2020 at 18:52 • 0 comments
    Screen repair
  • ram upgrade
    angelo-dising • 09/15/2020 at 17:27 • 0 comments
    i found this forum about the ram upgrade of a tablet:
    https://androidforums.com/threads/upgrading-ram-on-tablets.627236/
  • first steps
    angelo-dising • 09/15/2020 at 17:00 • 0 comments
    the photos taken today are  the first ideas of my proyect.
    i got an a tablet motherboard whit a A33 arm procesor quadcore at 1.3ghz, i want to make a pasive refrigeration for the procesor with a  piece of aluminium cut by dremel.
    It seems that the procesor its defective because gets warm a lot, and based of my research if this hapends its maybe defective, but for now i will keep searching more info.
  • Materials
    angelo-dising • 09/15/2020 at 16:51 • 0 comments
    HAKPAD
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
Assemble and Program Arduino Nano based Acoustic Levitation KIT
Project Owner Contributor
Arduino based Acoustic Levitation KIT
boian-mitovBoian Mitov
Microcontroller Audio Workshop & HaD Supercon 2015
paul-stoffregenPaul Stoffregen
Supplyframe DesignLab: 2022 Hackada…
Transform an old "slot-in record player": make a magical mp3 player with the help of RFID reader and tags
Slot-In Record Player with Arduino rfid & mp3
jean-noelJean Noel
Use an OLED screen to play pong in the palm of your hand! Simply plug in a micro USB cable and you're ready to play- with sound effects!
Handheld Arduino Pong Console
having11having11
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Hackpad", please tell us the reason.
Send message
Remove Member
