A Phillips/NXP PCF8574 8-bit I2C bus digital I/O expander emulator.
Finally! After a project hiatus, the first example code is uploaded to GitHub.
https://github.com/mdlougheed/I2CIO_PCF8574
This example code will use the I2CIO to emulate an 8-bit I2C digital I/O expander. Other I/O expanders, such as the TITCA9534.
The main idea with this code was to show how to set up a basic I2C receiver device. Other device possibilities are a sensor preprocessor to reduce raw data to a usable form, offloading that task from the controller device. How about an I2C connected fault tolerant co-processor array. Or maybe an SD card storage system accessible through I2C. The possibilities are endless.
