The PCBs have arrived. I'm not impressed with the quality but hopefully they'll work.
Lesson learned No.1: check the minimum silkscreen specifics of the fab house. I did at some point but, changes after changes, I ended up with characters smaller than the minimum requirement. As a result, the silkscreen in unreadable.
The mousebites worked well. These could also be smaller as they seem quite strong.
The soldered components look good. I'm glad I spent a few bucks more to have these assembled. The 0603 package is so small I doubt I would enjoy soldering by hand.
No worries though, there is plenty of other small things to solder. This on the next log.
ridoluc
