In the last version (called 0.7) I cleaned up a little bit the code, removed the redundant "message builder", and added "clean button".
also disabled file creation on start up - now new file is generated on starting the log.
A project log for Serial Data Visualization
Small .net based software that allows simplest possible data visualization and logging from serial port
