1Raspberry Pi OS (32bit) with deskop: (mirror tested version)
If you don't have Raspberry Pi OS pre-installed, please use this version:
https://rcn-ee.net/workshops/remoticon_2020/
It's a local mirror of https://www.raspberrypi.org/downloads/
Mirror of BalenaEtcher is provided for easy install thru Windows, Linux, and mac
If you have a different version of Raspberry Pi OS installed, just make sure you have the desktop version.
2Solder or use Breadboard. ;)
3Expose Sensor Wire
4Loop Wire thru Holes for support
5Place Resistor between 13 and 3v3
6Push White and Red wires into same 3v3 & 13 holes
7Flip and Solder
8Flip and Push Black in GND
9Flip and Solder GND
10TRIM
