The project uses a Teensy 4.1 as its main processing unit and storage device (SD card).
The FT81x Arduino Driver is used as a display system.
Wiring
Display
For display wiring please refer to this guide for the FT81x Arduino Driver.
Buttons
Button wiring is straight forward and doesn't require any pull-up resistors:
Audio
For proper audio output some filter and amplifier circuitry is required:
Tip: Audio output is most authentic with a Gameboy replacement speaker.
Running and Loading a Game
Game ROMs are not included with this repository and have to be provided via SD card! Make sure the SD card is formatted using the FAT32 filesystem using Master Boot Record partitioning style. File names should follow the 8.3 MS-DOS style.
As of now, the ROM to be loaded has to be specified inside src/main.cpp, e.g:
Cartridge::begin("tetris.gb");
Raphael Stäbler
Waldo Wolmarans
