A huge update for robot and RC is just released. I was working on it since summer (but not only on it of course).
Hardware update:
An extension board added. The board provides an easy way to connect different modules to power lines with different voltage and data interface lines (SPI, I2C, 1-Wire) without soldering.
![](https://cdn.hackaday.io/images/2550271602256067729.jpg)
FPV Camera has been moved to a place with a better view. So, the robot has become a little more compact.
![](https://cdn.hackaday.io/images/8172611602257045576.jpg)
Powerful lighting LED instead of 4 green LEDs which actually don't provide enough light to make the camera see anything in the darkness.
![](https://cdn.hackaday.io/images/5998301602256877276.jpg)
Small constructive improvements to the remote control case. No impressing photos.
Software update:
of robot: https://github.com/Danya0x07/DUMRON/releases/tag/v2.0 (in Russian)
- Refactoring names and CodeStyle, how can we do without it!)
- Moving the code for interaction with NRF24L01 + and DS18B20 into separate, cross-platform super-duper libraries with documentation, examples and other benefits of humanity;
- The DS18B20 library implements checksum verification, so the heresy about temperature no longer comes to the RC.
- Added power-on self test;
- Added debug logs to UART and runtime errors indication;
- Detected and fixed a stack overflow in one of the tasks;
- Various local optimizations (eg. uint8_t -> uint_fast8_t);
- Battery charge measurement now works not "head-on", but through DMA;
- Optimized manipulator control, now, when it does not move, its software timer does not spin idle, but stopped;
- The communication protocol with the RC has been rethought and optimized, the encapsulation of data from the rear rangefinder has been improved.
- Added detection of mechanical failure of the rear rangefinder;
- Migration to CMSIS-RTOS APIv2;
- Added the ability to change the radio frequency channel by command from the RC.
of remote control: https://github.com/Danya0x07/DUMRON_RC/releases/tag/v2.0 (in Russian)
- Migration to the PlatformIO build system;
- Moving the Nokia display Interaction code into a standalone PCD8544 cross-platform library;
- Added energy saving measures (redundant microcontroller subsystems are disabled);
- Added scanning of the radio frequency range after power on and switching the RC and the robot to the new selected clear channel;
- GUI updated and improved;
- Refactoring and optimization of various kinds;
