New Git found: "SUP Console Programmator"
A project log for Dissecting a hand-held NOAC console (Sup 400-in-1)
This is an attempt to understand how these little things work, and what we can do on it.
yh-workshopYH-workshop 02/23/2023 at 15:370 Comments
When trying to find ways and means to put our custom compilation inside the flash, I bumped into this very recent article (it is in Russian - you need a Google Translate) explaining about the dumping and the flashing process of the chip inside.
Also, the author documented the rest of the process in the Github (it is in Russian too - Google Translate works on it) - it is an extremely good read.
The method would help me to dump and flash the ROM faster, and also to help me understand that program inside better.
From the article, the pictures are the attempts to build a makeshift "cartridge" that holds that flash board and the "slot" connected to the SUP console:
(Source: Thanks to Aleksandr Serdyukov - https://habr.com/ru/post/718366/)
On that, I will try to build this too and experiment it! :)
