Okay, so I managed to examine the dump some more and trying to strip the startup code to its bare minimum.
However, on this particular newer dump, the code is significantly more complex than the previous one, due to the TFT init routines (that covers many other models apart from the GC9306), and also many other unknown registers such as 0x413x are being accessed.
Instead of stripping it first to see if it works or not, I grabbed the whole first 512K (0x80000) of the code and pasted into another empty bin file.
The startup code is just too much work to strip at the start so I filled the majority of the menu code from 0x6E000-0x6EFFFF with zeros and replaced it with another jump to another area away from that first 512K - to 0x82000:
; org 0x6E000: cpyToRAM_Loop LDA $E800,X STA $0400,X DEX BPL cpyToRAM_Loop JMP $0400 ; org 0x6E800: LDA #$00 STA $4100 LDA #$05 STA $4107 LDA #$01 STA $4108 LDA #$02
Converting this back to 6502 machine code and paste it, it should look like this:
These NOAC's bankswitching methods have to be copied into the RAM area and run it for it to work. Else, it won't go to the new address.
Of course, I tested this in the EmuVT 1.36 to see if it jumps to the address. When it does, I actually proceeded into writing more code at the 0x82000 onwards.
Note: The backlight seemed to be only switched on after the TFT init routine!
Compile this in ASM6F and paste the code into the section 0x82000:
helloText EQU $A200 ; ------------------ ; main program here: ; ------------------ .org $A000 main_app: ; diasble interrupts on APU: lda #$40 sta $4017 lda #$00 sta $4010 vblankwait1: ; First wait for vblank to make sure PPU is ready bit $2002 bpl vblankwait1 enableBacklight: lda #$1f sta $413f lda #$0b sta $4138 lda #$0f sta $4139 ; clear RAM: tax Init_ClearRAM: sta $000,x sta $100,x sta $200,x sta $300,x sta $400,x sta $500,x sta $600,x sta $700,x inx bne Init_ClearRAM Init_PPU_chr: lda #$00 sta $2012 lda #$00 sta $2013 lda #$00 sta $2014 lda #$00 sta $2015 lda #$00 sta $2016 lda #$00 sta $2017 lda #$20 sta $2018 lda #%00000000 sta $201A ; fill background with one value for 8 tiles: lda $2002 lda #$20 sta $2006 lda #$00 sta $2006 ldy #$00 FillAllBackground: FillBackground: lda #$00 sta $2007 inx cpx #$ff bne FillBackground iny cpy #$04 bne FillAllBackground ; Fill palette with 0x0f, 0x30, 0x30, 0x30: ; $3f00 = 0x0f FillPalette: lda $2002 lda #$3f sta $2006 lda #$00 sta $2006 ldx #$00 FillPalleteLoop: lda #$0e sta $2007 lda #$0e sta $2007 lda #$2a sta $2007 lda #$0e sta $2007 inx cpx #$04 bne FillPalleteLoop PrintText: lda $2002 lda #$20 sta $2006 lda #$00 sta $2006 ldx #$00 Print0: lda helloText, x cmp #$00 beq PrintDone sbc #$20 sta $2007 inx jmp Print0 PrintDone: Init_PPU: lda #%10000000 sta $2000 lda #%00001010 sta $2001 lda #$0 sta $2005 sta $2005 here: jmp here ; ------------------ NMI: rti .org helloText .db "HELLO WORLD!", #$00
Wait - you need to put the CHR into the area 0x80000 too. Sample CHR file provided - get the "chicago_oblique_basic.chr". I got the sample CHR from the NesDev forums, and paste it at the 0x80000 area. It should look like this:
After all is done, program this bin into the NOR flash using the T56 programmer (or any other equivalent). You should be seeing this one:
