Dissecting the startup!
A project log for Dissecting a hand-held NOAC console (Sup 400-in-1)
This is an attempt to understand how these little things work, and what we can do on it.
yh-workshopYH-workshop 03/31/2024 at 03:410 Comments
As mentioned in the previous logs, if you have used this method, you may able to get the dump and run this binary in the EmuVT emulator.
So on about last year, I actually dissected the flow of the program and written it into a piece of paper. This analysis does not include how the game menu works and the test screen - only the startup.
Using the EmuVT emulator and putting breakpoints one by one, I managed to see things like:
These are also verified using the homebrew flash emulator that dumps part of the ROM ($60000-$80000) into the Teensy 4.1.
With the flash emulator, using the stripped ROM, I managed to try adding a while loop at certain places in the ROM (usually 4C xx xx) to 'halt' the program. This is useful when I want to see when the backlight gets switched on. Initially, it is thought that the backlight is switched on at the TFT initialization routines. However, putting the command inside does not work (backlight doesn't lit up), and I had to try adding this 'halt' between the function calls when the menu is running. When one of the locations are being known to switch on the backlight, I focused into it and found out that putting the $0F into the $412C actually does this thing.
I dumped two of these ROMs (one bought in 2020, and another somewhere later) and one of them have swapped bits 1-2 and 9-10 at the data pins! Some of them have very different starting vectors too - one started at $FF00, and one at $FEF5. However, they all use the same mentioned registers and these apps could possibly work on another similar Sup 400-in-1 consoles.
One more issue - where are the registers that controls the external sound speakers?
