Hackaday.io Hackaday.io
Sign up Log in
Transistorless Sound Synthesizer
A home brew mini-synth idea using no transistors with the Patrick Oscillator
dr-cockroachDr. Cockroach
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.8k views
16 comments
23 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 9
    • View all
  • Instructions 0
  • Discussion 16
View Gallery
2.8k
16
23
20
Team (1)
  • dr-cockroachDr. Cockroach
Join this project's team
hardware
ongoing project
light logic led CdS photo resistor synthesizer sound MUSIC Mark nesselhaus patrick flett monophonic passive Synth
Related lists
Guitars
Parts of guitars
This project was created on 10/11/2020 and last updated 5 年前.
Description
Thanks to a circuit by Patrick Flett, I have a idea to develop his Patrick Oscillator into a mini synthesizer. This circuit uses the same Led/Cds photo resistor pairs that I use for Light Logic and Patrick shared his circuit with me in late September 2020 when we met on You Tube.
As of now, this synth is Monophonic just to keep the circuit as simple as possible.
As with my more recent projects, this one does not use any transistors but it does perform quite well as it is. It even drives my headphones to a comfortable level so no extra amp is needed.
Goal is to make a patch panel along with switches and variable pots to make use of all possible subtle sound output combinations as well as make or modify a basic piano style keyboard of one or two octaves.
Project Logs
Collapse
  • Let the circuit bending/blending begin
    Dr. Cockroach • 11/23/2020 at 15:48 • 0 comments
    I have decided to begin blending the Patrick oscillator and other circuits to the keyboard. The circuits are mounted and just need the interconnects added.
  • Where is this heading????
    Dr. Cockroach • 10/28/2020 at 21:20 • 0 comments
    October 28, 2020 -  I am at a bit of a crossroads with this project. I will continue to explore just how much I can expand the range of sounds with this oscillator but now I also want to build a multi voice drone similar to what Sam from Look Mum No Computer fame has made at https://www.lookmumnocomputer.com/
    If you have a moment then check out his projects. All are Mad Good but I really love the Drone of his and I think I can make at least a 5 to 10 voice example. Check out his Megadrone https://www.lookmumnocomputer.com/projects#/1000-oscillator-megadrone
    And if I make a batch of oscillators then I could have a basic and messy polyphonic system in its beginning stages.
  • Testing the Theremin effect and a LFO
    Dr. Cockroach • 10/25/2020 at 13:01 • 0 comments
    October 25, 2020 - Video of current tests of the LFO and perhaps make a Passive Optical Theremin
  • First test scale
    Dr. Cockroach • 10/14/2020 at 22:09 • 5 comments
    October 14, 2020 - First test scale using the very basic keyboard. I still need to add the sharp/flat keys but this taking shape.
  • Tuning and Keyboard Module
    Dr. Cockroach • 10/14/2020 at 15:22 • 0 comments
    October 14, 2020 -  Starting the layout of the tuning pots and keyboard switches.
  • The Basic Circuit
    Dr. Cockroach • 10/14/2020 at 10:53 • 0 comments
    Here is the basic circuit I am using. Pardon my poor sketch ;-)
  • Switches for the keyboard
    Dr. Cockroach • 10/13/2020 at 21:07 • 0 comments
    October 13, 2020 - I found some very small switches in my junk box that will do for a small push button keyboard. Not ideal but good enough for testing. These were from a printer/copier that my landlord gave to me so why not make use of some of those parts. This will be a single octave from C2 through to C3 plus a extra key on the left for a knob controlled tone. Right now the oscillator has a hard time reaching C4 so going with the lower octave. Besides I love the deep rich sound this circuit has down there :-)
  • The perfect multi-turn pot ???
    Dr. Cockroach • 10/13/2020 at 12:44 • 3 comments
    October 13, 2020 -  I have had this old TV tuner board in my junk box for about thirty years and I think these 20K pots will be of great use in the tuning of the keyboard part of this project. These pots take about 100 turns for full range. Very fine tuning indeed ;-)
  • How it sounds in the raw so far
    Dr. Cockroach • 10/11/2020 at 18:53 • 0 comments
    October 11, 2020
    This is just a sample of the deep low sound from the Patrick Oscillator. Very low frequencies and sounds great.
View all 9 project logs
Log In/Sign up to comment
Sign up with Github
OR
Yann Guidon / YGDES wrote 10/27/2020 at 03:00 • point
I'd love to build a polyphonic one...
Dr. Cockroach wrote 10/27/2020 at 10:42 • point
Actually, I have already started on that. All I need for the single octave is one oscillator for each note. As long as I keep it simple XD
Ken Yap wrote 10/25/2020 at 05:12 • point
Cool! You should make a few and start an ensemble. As they say, many hands make light work. 🤣
Dr. Cockroach wrote 10/25/2020 at 09:43 • point
Now that would be cool :-)
Dr. Cockroach wrote 10/25/2020 at 09:44 • point
Light work.... Ooooooooo
Light Work, I love it :-)
Yann Guidon / YGDES wrote 10/25/2020 at 00:50 • point
Doctor, you did it again !
https://hackaday.com/2020/10/24/a-transistor-less-sound-synthesizer/
I guess so but in all fairness Patrick Flett invented the circuit, I just pounced on it as a possible passive synth sound machine :-)
Hari Wiguna wrote 10/24/2020 at 23:38 • point
Patrick Flett explains how it works in this video:
https://www.youtube.com/watch?v=fYMWZ75iO8g
Dr. Cockroach wrote 10/25/2020 at 09:38 • point
Yes, I am so glad that Patrick shared his circuit with me and now I am expanding on it to where it might actually be a very flexible synth.
Dan Maloney wrote 10/14/2020 at 18:37 • point
I'm struggling to understand how the oscillation happens. I thought it required amplification and a positive feedback loop. Going to have to dig into this one a bit more - thanks for the head-scratcher. Like the way it sounds, BTW.
Dr. Cockroach wrote 10/14/2020 at 21:01 • point
I am struggling with the concept myself. My led/CdS Logic is easy enough to follow but this circuit confounds me a bit ;-)
Ken KD5ZXG wrote 10/15/2020 at 19:33 • point
if not inverting, perhaps just a relaxation oscillator.
mh-nexus wrote 10/14/2020 at 17:48 • point
Hi, interesting project.
I assume you meant this Patrick Flett: https://www.youtube.com/channel/UCdY0rnioc1twUgD6JwpuXvg
Maybe saying a bit more than providing a schematic would help to better understand how you want to make a synthesizer. Or do you just aim at making some sine wave sounds?
Dr. Cockroach wrote 10/14/2020 at 21:00 • point
Yup, same person, he found my Light Logic videos and we have exchanged some ideas and he sent me his schematic. This is my first real attempt at a synthesizer of any kind and this is the start of a very interesting build if I can maintain the transistorless aspect of it. The very simple keyboard is now working and tuned. I will post as I learn more and develop this project
Dr. Cockroach wrote 10/14/2020 at 21:08 • point
I would like to add loops and feedback as well as filtering but that will still be a step by step adventure for me :-)
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Transistorless Sound Synthesizer", please tell us the reason.
Send message
Remove Member
