Supplies:
Browser with internet access. That is it
Question 1: What Are the Useful Features to Be Present in an Arduino Simulator?
A good Arduino simulator should have these features:
- Support multiple file projects📁📂📂🗄🗃 (*.h, *.cpp and more)
- It should be able to use Arduino libraries (not just a few😟 but all😀)
- Latest🆕 Arduino version should be used by default (Reason and more info)
- Support various trending projects which have many users - FastLED support, OLED, TFT colour LCD, NeoPixel 🤩 and more
- Arduino Mega simulations and Arduino nano simulations
- Examples for Demo projects (for example: famous libraries on GitHub)
- Should be able to run on multiple platforms - Windows, Mac as well as Android (Mobile devices 📱)
- Sharing🌏🌐 options so that it will be easy to share code with others (to get help, to get a review or some additions done)
- Be Smart
- Support code auto-complete
- support code formatting
- special useful debug features (example FPS and LED 🚥💡⚡Watt indicator for LED projects) etc
- Features provided should not be limited
- some NeoPixel Arduino projects have limitations👎 on the number of LEDs that can be connected
- Simulated parts: A good Arduino simulator is as good as the number of useful simulated elements it has. If the simulated elements are less, either the project will be handicapped or there will be less motivation.
- Support- There is no software tool which will be free of bugs or which will be in need of improvements. There should be a commitment from the developers to keep the tool up-to-date and also respond to the users in a timely manner. A tool which stops updating is a no go
PS: <please suggest if I should add any other points>
Question 2: How Many Files and Filetypes Are Supported in Wokwi Arduino Simulator?
There is always a need to add more functions to the project which will be done via the library. this will provide more useful features to the existing projects as well. Wokwi Arduino simulator supports library files written in C *.c, CPP *.cpp and the header *.h files, without any restrictions.
Other file types supported by standard Arduino IDEare also supported.
Many simulators fail here as they either support only built-in libraries or doesn't support the external libraries at all. This is a disadvantage of using other simulators because in this world of open-source there are so many useful libraries out there for multiple projects, it will be a big loss for a learner to not to have the ability to play with them.
Question 3: How Does Wokwi Arduino Simulation Always Uses Latest Arduino Version?
Wokwi doesn't ask you to download any software package
it also doesn't need any installations
These two steps are avoided making the user free of maintenance work (frequent updates or outdated IDE usage are upfront avoided)
Question 4: What Are Some Interesting Library Examples Wokwi Hosts?
Wokwi Arduino simulator has many built-in examples listed on exciting modules such as NeoPixels, OLEDs and more. Here are a few examples:
- NeoPixel library from Adafruit:
https://wokwi.com/arduino/libraries/Adafruit_NeoPi...
- SSD1306 OLED display library from AdaFruit
https://wokwi.com/arduino/libraries/Adafruit_SSD13...
- DHT sensor library from Adafruit as well
https://wokwi.com/arduino/libraries/DHT-sensor-lib...
- FastLED examples from various contributors on GitHub (all references to the original author provided)
https://wokwi.com/arduino/libraries/FastLED
- Servo motor and potentiometer examples
and many more.
Bottom line is that the Wokwi Arduino simulator makes learning easier with the ample amount of good examples provided to get one started🏇.
PS:<If you have any suggestions for adding more libraries, you are always welcome. Please leave a comment>
没有MAX6675这个库文件,我的程序不能运行
