Truncated Icosahedron
Soccer ball shaped polyhedron made of drinking straws
60 x 3D printed vertices join 90 x 4cm drinking straw snippets into a soccer ball.I got all my knowledge about this shape from:https://en.wikipedia.org/wiki/Truncated_icosahedron
SoccerVertexX12.stl
Standard Tesselated Geometry - 697.35 kB - 10/15/2020 at 02:38
Download
SoccerVertex.f3d
fusion - 108.52 kB - 10/15/2020 at 02:38
Download
SoccerVertex.stl
Standard Tesselated Geometry - 58.19 kB - 10/15/2020 at 02:38
Download
  • Learning by doing
    Hari Wiguna • 10/12/2020 at 02:34 • 0 comments
    I started with a dodecahedron.
    I made the 3D printed vertex to be a sleeve for all the straws to "plug" into.
    Then I realize that it would be faster to print and prettier too if I insert the straw into the vertex!
    I found that multiplying the object in Fusion rather than in Cura creates a more efficient packing.
    I have 12 in the model then I multiplied it five times in Cura for a total of the needed 60 vertices.  I think it took 8 hours to print on the Ender 3.
View project log
View all instructions
rakelgomez wrote 05/22/2023 at 11:14 • point
With this figure I have just made a modern lamp for my son. Very interesting!
Neon22 wrote 10/14/2020 at 21:03 • point
There's a start at a parametric openSCAD version here: https://www.thingiverse.com/thing:2587058/files
I'd be happy to help create a general solution given a set of angles, or polyhedron def of some kind.
Hari Wiguna wrote 10/15/2020 at 02:43 • point
That'd be cool!
The Truncated Icosahedron is made up of pentagons surrounded by hexagons.
Angle between pentagon and hexagon are 142.62°
Angle between hexagon are 138.189685°
More info at wikipedia: https://en.wikipedia.org/wiki/Truncated_icosahedron
Please let me know the link to the openscad version. when you got it working.
Thanks!
Hari Wiguna wrote 10/14/2020 at 19:33 • point
Sure, I'll upload it to thingiverse tonight and add a link to it here.
No guarantee how well the fit would work for everyone's printer.  I suppose you could scale it until it fits snugly for your printer and straw.
Michail Wilson wrote 10/14/2020 at 17:32 • point
Neat.  Were you going to provide the STL files?
Hari Wiguna wrote 10/15/2020 at 02:45 • point
https://www.thingiverse.com/thing:4624175
PS: Neon22 is going to make an OpenSCAD version too
