cat scrapping post
standing post for a cat, for scrapping
This is a project for creating a cat scrapping post/house with generic components and some printed stuff.
Rope usage is something like 25 metres per 0.5 metre of the 75mm pipe. If you get longer pipe - just multiple by the additional 0.5 blocks used. If you get wider rope (like 8mm) - this is great for the purpose and more importantly you need less metres.
75mm pvc pipe lid v3.stl
The upper part of the connection with a hook to hang toys or feathers.
Standard Tesselated Geometry - 2.33 MB - 10/20/2020 at 20:28
Download
75mm pvc pipe lid no hook v3.stl
This version doesn't include a hook for hanging cat's toys. It's supposed to go to the bottom part of the connection.
Standard Tesselated Geometry - 914.83 kB - 10/20/2020 at 20:28
Download
  • 1 × 75mm PVC pipe 1m
  • 1 × plywood 450mm x 800mm, 8mm
  • 25 × Sisal rope, 6mm or 8mm diameter (see description)
  • 50 × screws 4.0x16mm
  • 50 × wood/metal screws 4.0x25
View all 2 project logs
Rich text editor
Dr. Cockroach wrote 10/13/2020 at 19:31 point
A good idea that I need to try. My cat goes through store bought scratching pads very quickly and I need to put down my soldering iron for a change and make something like that :-)
Georgy Grigoryev wrote 10/14/2020 at 08:55 point
The easiest solution would be just to replace a rope if it gets too worn.
Dr. Cockroach wrote 10/14/2020 at 10:38 point
Very true and the price for one of these is too high in the store considering the materials used. Better to make it at home. Good job :-)
