Building the LED tubes:
A project log for Control My Lights
Control My Lights using a website, Twitch chat, YouTube chat. controlmylights.net
edward-c-deaver-ivEdward C. Deaver, IV • 10/16/2020 at 20:40•0 Comments
To create the LED tubes, I got  8-foot plastic tubes, normally used for premade lights, from Home Depot. I created an 8-foot strand of lights from 2 4’ lights for one tube, and ordered an 8-foot strand for the other. You may notice that once inside the tube you can’t pull the strip to expose the adhesive. I found a YouTube video that said to use a fishing hook and hook it into the adhesive. Instead of a fishing hook I found a rubber coated paper clip works well. When you are doing this make sure the paper clip is closed up and not fashioned like a hook. If it’s like a hook it will catch on your LEDS and you’ll have to make an incision in your tube to fix it. To diffuse the light, I used parchment paper.
Here is a fast-forward video of building one of the tubes:
