Kyle - Pi 4b/8G NVMe
Stan - Pi 4b/8G NVMe
Cartman - Pi 4b/8G NVMe
Kenny - Pi 4b/8G 500G 7200rpm spinning rust
Butters - Pi 4b/8G 500G Crucial flash sata
A console node for serial ports - Pi 3b+
K8console - Pi 3B+ MicroSD
Now there is a need for log aggregation. This design will use Fluentd on the OS and Fluent-bit on the microk8s cluster. The log destination will be to a Elasticsearch node with Kibana installed.
Installed another Pi 4 / 4G with the new Ubuntu 20.10 64 bit release ( no desktop). This release does not require the MicroSD card to boot - so I've used a SATA flash disk here.
Adding this new node that runs Elasticsearch and Kibana.
Ike - Pi 4b/4G 240G Crucial flash sata
CarbonCycle
