Following the instructions here: Adding nodes
ubuntu@Node-1:~$ microk8s kubectl get all --all-namespaces -o=wide
NAMESPACE NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES
ingress pod/nginx-ingress-microk8s-controller-4tb5s 1/1 Running 1 6h33m 192.168.1.40 node-3 <none> <none>
kube-system pod/calico-node-ggdrf 1/1 Running 1 3d4h 192.168.1.40 node-3 <none> <none>
ingress pod/nginx-ingress-microk8s-controller-kj8lt 1/1 Running 2 6h33m 192.168.1.41 node-2 <none> <none>
kube-system pod/hostpath-provisioner-976f6d665-j7sgl 1/1 Running 1 3d19h 10.1.247.2 node-2 <none> <none>
kube-system pod/calico-node-gh6jz 1/1 Running 1 3d20h 192.168.1.41 node-2 <none> <none>
ingress pod/nginx-ingress-microk8s-controller-hkxqd 1/1 Running 1 6h33m 192.168.1.30 node-1 <none> <none>
kube-system pod/calico-node-449m7 1/1 Running 1 3d20h 192.168.1.30 node-1 <none> <none>
kube-system pod/calico-kube-controllers-847c8c99d-9nx7p 1/1 Running 1 3d20h 10.1.84.132 node-1 <none> <none>
kube-system pod/coredns-86f78bb79c-ngbnx 1/1 Running 1 3d20h 10.1.84.131 node-1 <none> <none>
NAMESPACE NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE SELECTOR
default service/kubernetes ClusterIP 10.152.183.1 <none> 443/TCP 3d20h <none>
kube-system service/kube-dns ClusterIP 10.152.183.10 <none> 53/UDP,53/TCP,9153/TCP 3d20h k8s-app=kube-dns
NAMESPACE NAME DESIRED CURRENT READY UP-TO-DATE AVAILABLE NODE SELECTOR AGE CONTAINERS IMAGES SELECTOR
ingress daemonset.apps/nginx-ingress-microk8s-controller 3 3 3 3 3 <none> 6h33m nginx-ingress-microk8s quay.io/kubernetes-ingress-controller/nginx-ingress-controller:0.33.0 name=nginx-ingress-microk8s
kube-system daemonset.apps/calico-node 3 3 3 3 3 kubernetes.io/os=linux 3d20h calico-node calico/node:v3.13.2 k8s-app=calico-node
NAMESPACE NAME READY UP-TO-DATE AVAILABLE AGE CONTAINERS IMAGES SELECTOR
kube-system deployment.apps/hostpath-provisioner 1/1 1 1 3d19h hostpath-provisioner cdkbot/hostpath-provisioner-arm64:1.0.0 k8s-app=hostpath-provisioner
kube-system deployment.apps/calico-kube-controllers 1/1 1 1 3d20h calico-kube-controllers calico/kube-controllers:v3.13.2 k8s-app=calico-kube-controllers
kube-system deployment.apps/coredns 1/1 1 1 3d20h coredns coredns/coredns:1.6.6 k8s-app=kube-dns
NAMESPACE NAME DESIRED CURRENT READY AGE CONTAINERS IMAGES SELECTOR
kube-system replicaset.apps/hostpath-provisioner-976f6d665 1 1 1 3d19h hostpath-provisioner cdkbot/hostpath-provisioner-arm64:1.0.0 k8s-app=hostpath-provisioner,pod-template-hash=976f6d665
kube-system replicaset.apps/calico-kube-controllers-847c8c99d 1 1 1 3d20h calico-kube-controllers calico/kube-controllers:v3.13.2 k8s-app=calico-kube-controllers,pod-template-hash=847c8c99d
kube-system replicaset.apps/coredns-86f78bb79c 1 1 1 3d20h coredns coredns/coredns:1.6.6 k8s-app=kube-dns,pod-template-hash=86f78bb79c
ubuntu@Node-1:~
I've enabled DNS, ingress and the (local) storage provider.
