1. Pin the tail on the Donkey. Manual PVC placement to a specific PV
The storageClass declaration
kind: StorageClass
apiVersion: storage.k8s.io/v1
metadata:
provisioner: kubernetes.io/no-provisioner
reclaimPolicy: Retain
# must use WaitForFirstConsumer to enable topology-aware scheduling, won't bind PVS until a pod using it is scheduled
volumeBindingMode: WaitForFirstConsumer
A brief explanation of the sc is:
provisioner - none. Well, actually its a protein-robot (you) provisioner.
reclaimPolicy - There are others, this one is appropriate for persisting things like databases.
volumeBindingMode - This is key for the method. The PV will WaitForFirstConsumer.
The Persistent Volume declaration
apiVersion: v1
kind: PersistentVolume
metadata:
spec:
capacity:
storage: 1Gi
volumeMode: Filesystem
accessModes:
- ReadWriteOnce
persistentVolumeReclaimPolicy: Retain
claimRef:
namespace: ""
storageClassName: db-storage
local:
path: /mnt/pv1
nodeAffinity:
required:
nodeSelectorTerms:
- matchExpressions:
- key: kubernetes.io/hostname
operator: In
values:
- <FQDN-dns-hostname>
Design:
The idea is to create a valid PV object and have it associated with a specific node where the storage exists. Once deployed, the two items with empty quotes not appear when you edit the pv. claimRef will be "claimRef: {}". Once you have the PVC name and namespace (found in the waiting pod's describe output), edit the pv object ( kubectl edit pv PVname ) and add those two back with the namespace name and PVCname found waiting ( kubectl get pvc -n namespace-name ).
A brief explanation for the pv:
PVname - I like to use a name that indicates the size of the physical storage.
accessModes - This means only one node can directly write to the storage, not a shared storage in that sense.
persistentVolumeReclaimPolicy - this provides some persistence guarantee.
claimRef - described above.
storageClassName - is chosen to obtain the desired volumeBindingMode.
path - the actual path on the host. Should be in /etc/fstab and mount at boot.
nodeAffinity - this section associates the physical storage to a specific node/host. Look at a node describe to find the specific string in
CarbonCycle
