Old Light
Previously, I had used a ring light bought off of Aliexpress. It worked well from a functional standpoint. However, there were some issues with it.
- Mounting it required a custom designed bracket
- It was wide enough to limit head travel distance.
- It has a power converter that was attached to the wires which was an awkward place.
![Old Ring Light Old Ring Light](https://cdn.hackaday.io/images/7602231651676363904.jpg)
Custom Light
My friend designed a custom light to solve these issues and add functionality.
- Mounting compatible with ELP cameras.
- Same width as ELP cameras.
- Onboard power adaption.
- Adjustable light output (dimming).
![Ikosy Pick and Place Lighting Module Ikosy Pick and Place Lighting Module](https://cdn.hackaday.io/images/6028751651676410288.jpg)
