If using this module on your MZ-32, you want to make sure you connect the servo wire CORRECTLY to the DATA PORT on the back of the Tx. There is NO notch on the data pin ports to prevent you from installing it backwards!
Make sure you look at the picture below to see the correct orientation! The GND (black) wire goes to the RIGHT MOST pin of the 3-pin DATA port!!!!
![](https://cdn.hackaday.io/images/6521821603064504366.jpg)
