Nr. 17
06/02/2022 at 19:30 • 0 comments20220602 - 21:24 - no tombstones.
Nr. 16
05/29/2022 at 21:23 • 0 comments -
Nr. 15
05/19/2022 at 21:53 • 0 comments20220519 - 23:44 - no tombstones.
Nr. 14
05/11/2022 at 20:27 • 0 comments20220511 - 22:17 - no tombstones.
Nr. 13
05/01/2022 at 20:50 • 0 comments20220501 - 11:11 - no tombstones.
Nr. 12
04/24/2022 at 21:05 • 0 comments20220424 - 15:35 - 360R didn't sink into one of the pads. That counts!
I also accidentally used low temp paste on this board, so it's double cursed.
Nr. 7 also had a problem with the 360R resistor, maybe that value is especially sensitive.
Nr. 11
04/18/2022 at 20:10 • 0 comments20220418 - 21:47 - no tombstones.
Nr. 10
04/15/2022 at 21:36 • 0 comments20220415 - 23:29 - no tombstones.
Nr. 9
04/04/2022 at 18:01 • 0 comments20220404 - 19:54 - no tombstones.
Paste for 240 and 360 Ohm resistors required manual rework prior to reflow because of sloppy squeegee action.
Nr. 8
03/30/2022 at 20:53 • 0 comments20220330 - 20:05 - no tombstones.
I do admit that I swapped two resistors. Might be significant.
