Plywood math surface
A wood sculpture milled with my CNC
This is done with 31 sections on one axis and 3 smaller sections on the other axis.
The project is designed to be cut on from 3.2mm thick plywood on a CNC capable of working pieces up to 300mm*300 mm.
You can find the dxf files on Thingiverse at the link provided.
Sections.dxf
31 Sections of the surface
AutoCAD DXF - 1.21 MB - 10/19/2020 at 17:38
Download
Supports.dxf
3 Sections acting as holders
AutoCAD DXF - 263.35 kB - 10/19/2020 at 17:38
Download
