arduino_lidar_3.py
Running one vl53l0x with the Python example code is pretty easy but running 2 or more is harder because you have to reset each one and set the I2C address. It loses the address on each reboot so you have to set them every time
chkserial.py
Small Python program to read the USB serial data and print to screen. I used this code on a Raspberry Pi to read the distances from the arduino running the vl53l0x code plugged into the Pi's USB port and drive a robot based on the distance readings.
HACKRC
Bart van der Wee
tinandjar
ZaidPirwani
