To finish off the top cover I want to add a hinge for the front door. The hinge should open 180° and rest in the upper position as well in the lower.
The design process:
A project log for CHANGER - a toolchanger new interpreted
CHANGER - a motion system which can be used for advanced 3D-Printing with up to four materials, PnP, PCB-Milling, Layer inspection, etc...
The design process:
