The started building process of my third topcover design is slowly taking shape:
After some printing (roughly 60h) there's some progress visible...
Some impressions:
All parts are designed in a way that there are minimal supports needed as you can see in the picture above. This angle without support and 0.2mm layer-height is no problem at all.
The back portion of the topcover is printed and assembled and I think it could look good. I didn't order the panels yet because I want to see if I'm fully satisfied with the look of it.
Front-top part WIP
