As it turns out everything can be solved by excessive quantities of hot glue.
This current CAD design is out of date, as i rearranged the wing configuration on the fly. In order to improve flow over the rear wing i displaced it downwards, hopefully it will now take advantage of the downwash from the forward wing, which will take advantage of the boundary layer ingestion of the ducted fan.
